how to setup boundary condition
Old   April 8, 2004, 20:23
Default how to setup boundary condition
young
hi all. it seems not trivial for me to set up the proper boundary condition even for the channel flow. could anybody give me some help ? here is the way i tried, which gave me the blown solution only.
u : upper(0), lower(0), inlet(float), outlet(float) v : upper(0), lower(0), inlet(0), outlet(float) p : upper(float), lower(float), inlet(pi), outlet(po)
i am using SIMPLE algorithm, which might be the cause of this chaos. thank you.
Old   April 8, 2004, 23:13
Default Re: how to setup boundary condition
Des Aubery
It would help if you stated which package/software you are using.
Regards, Des Aubery... (adTherm Technology - ww.adtherm.com)
Old   April 9, 2004, 02:30
young
hi Des~ i made my own code in matlab using SIMPLE algorithm. have a good day~
sincerely, young
Old   April 10, 2004, 05:34
versi
u,v = streamwise extrapolation at outlet.
Old   April 11, 2004, 20:57
young
thanks a lot, versi. let me try it.
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 06:05
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
problem with boundary condition??? smn CFX 5 November 24, 2009 07:37
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
