How do I monitor the turbulence of the flow?
Old   March 22, 2010, 09:40
Default How do I monitor the turbulence of the flow?
Heng Wei Ching
HengC is on a distinguished road
I am new in CFD. Can I know how do I monitor the turbulence of the flow at a specific surface, in my case the inlet and outlet. Thanks.
HengC is offline   Reply With Quote
Old   March 22, 2010, 13:54
Skeptic
Lysistrata is on a distinguished road
Originally Posted by HengC View Post
You can guess it, or you can pretend that you understand turbulence (when nobody else does) and make a calculation based on some form of voodoo.
Lysistrata is offline   Reply With Quote
Old   March 23, 2010, 15:57
N/A
harishg is on a distinguished road
Write the output of velocity at few points on the surface with time. If you are performing unsteady calculations, you should observe fluctuations in the fields. Also you can write out snapshots of the flowfield on the surface at different times and visualize it. You should be able to see the instantaneous flow structures.
harishg is offline   Reply With Quote
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 05:30
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
Buoyancy generated Turbulence flow Nitesh FLUENT 1 July 13, 2006 19:58
I have a problem about the turbulence flow! yuchang FLUENT 6 June 27, 2003 01:50
