ADI
Old   April 6, 2004, 06:23
Default ADI
arash
It is strange but I can not make an ADI program work for a 2-D heat conduction equation with Forward Time Central Space. I wrote a program that sweeps in X-direction and then Sweeps in Y-direction . But the results are not ok. Is there anything wrong? anyone can help please?
Old   April 6, 2004, 06:40
Default Re: ADI
Sergey Smirnov
It looks like you have an explicit scheme, for which you do not need ADI. ADI means Alternating Direction _Implicit_ method, doesn't it
Old   April 6, 2004, 06:45
Default Re: ADI
arash
I know what is ADI, and it is a two step method that solves the 2d heat equation implicitly at each half time steps. if you like, please have a look at the code:
! Program for 2D Heat Conduction Equation with ADI/FTCS ! FTCS= Forward Time Central Space ! Equation is Non-dimensionalized as: DT*/Dt*=D2T*/Dx*2+D2T*/Dy*2
real to(100,100),t(100,100),tm(100,100)
real dx,dy,dt
integer ni,nj,ntstep
real a(100),b(100),c(100),d(100),f(100)
xl=1.
yl=1.
ni=21
nj=21
dt=0.0001
ntstep=1000000
100 ddx=xl/real(ni-1) 101 ddy=yl/real(nj-1)
write(*,*),'End Time=',ntstep*dt
! Initial values
do i=1,ni
do j=1,nj
to(i,j)=0.0
enddo
enddo
! Boundary conditions
do j=1,nj
to(1,j)=1.
enddo
do i=1,ni
to(i,1)=1.
enddo
NTIME=1
DX=dt/(ddx**2.)/2.
DY=dt/(ddy**2.)/2.
37 continue
! Y- ! FTCS Implicit ! a,b,c coeffcients
do i=3,ni-2
c(i)=-DX
b(i)=1.+2.*DX
a(i)=-DX
enddo
c(2)=-DX
b(2)=1.+2.*DX
a(2)=0.
c(ni-1)=0.
b(ni-1)=1.+2.*DX
a(ni-1)=-DX
! Y-sweep starts here
do j=2,nj-1
do i=3,ni-2
RHSI=to(i,j+1)-2.*to(i,j)+to(i,j-1)
d(i)=to(i,j)+DY*RHSI
enddo
RHS2=to(2,j+1)-2.*to(2,j)+to(2,j-1)
d(2)=to(2,j)+DY*RHS2+DX*to(1,j)
RHSNIM1=to(ni-1,j+1)-2.*to(ni-1,j)+to(ni-1,j-1)
d(ni-1)=to(ni-1,j)+DY*RHSNIM1+DX*to(ni,j)
call tridag (ni,a,b,c,d,f)
do ii=2,ni-1
tm(ii,j)=f(ii)
enddo
enddo
! X- ! FTCS Implicit ! a,b,c coeffcients
do j=3,nj-2
c(j)=-DY
b(j)=1.+2.*DY
a(j)=-DY
enddo
c(2)=-DY
b(2)=1.+2.*DY
a(2)=0.
c(nj-1)=0.
b(nj-1)=1.+2.*DY
a(nj-1)=-DY
! X-sweep starts here
do i=2,ni-1
do j=3,nj-2
RHSJ=tm(i+1,j)-2.*tm(i,j)+tm(i-1,j)
d(j)=tm(i,j)+DX*RHSJ
enddo
RHS2=tm(i+1,2)-2.*tm(i,2)+tm(i-1,2)
d(2)=tm(i,2)+DX*RHS2+DY*to(i,1)
RHSNJM1=tm(i+1,nj-1)-2.*tm(i,nj-1)+tm(i-1,nj-1)
d(nj-1)=tm(i,nj-1)+DX*RHSNJM1+DY*to(i,nj)
call tridag (nj,a,b,c,d,f)
do jj=2,nj-1
to(i,jj)=f(jj)
enddo
enddo
NTIME=NTIME+1
IF(NTIME.ge.ntstep) then
goto 117
else
print*,NTIME*dt
goto 37
endif
! Writing Results in a File 117 print*,'end................................',NTIME *dt
open(unit=15,file='t.dat',form='formatted',status= 'unknown')
write(15,*) 'VARIABLES= X Y T'
write(15,82) ni,nj 82 format(1x,'ZONE T="Zone-One", I=',i3,' ,J= ',i3,' ,F=POINT')
do j=1,nj
do i=1,ni
write(15,88)real(i-1)*ddx,real(j-1)*ddy,to(i,j)
enddo
enddo 88 format(1x,3(1pe15.6,2x)) close(15)
end
c-----------------------------------------------------------------------
subroutine tridag (n, a, b, c, d, f) c----------------------------------------------------------------------- c..source: numerical recipies (modified) c..IMP: this is written to work in 2 to n-1 set c..computes the solution vector of a tridiagonal system of linear c..equations. a,b,c contain influence coefficients A(j-1),A(j),A(j+1). c..d contains the known right hand side. solution returned in f. c..a(2) and c(n-1) are not used
real a(n),b(n),c(n),d(n),f(n)
real gam(256)
bet = b(2)
f(2) = d(2)/bet
do i=3,n-1
gam(i) = c(i-1) / bet
bet = b(i) - a(i)*gam(i)
if(bet.eq.0.) pause 'tridag failed'
f(i) = (d(i) - a(i)*f(i-1)) / bet
end do
do i=n-2,2,-1
f(i) = f(i) - gam(i+1)*f(i+1)
end do
return
end
Old   April 6, 2004, 07:03
Default Re: ADI
Sergey Smirnov
If you have a forward time scheme, you do not have an implicit system that you would need ADI method (or any other iterative method, for that matter) to solve. You have an _explicit_ relation for the temperature at each new time level. It is only when you have backward time or Crank-Nicolson scheme that you need ADI.
Does your scheme look like this?
(T(i,j,n+1)-T(i,j,n))/dt = (T(i+1,j,n)-2*T(i,j,n)+T(i-1,j,n))/dx^2 + (T(i,j+1,n)-2*T(i,j,n)+T(i,j-1,n))/dy^2
where n is a time index and i,j are space indices.
Old   April 6, 2004, 07:22
Default Re: ADI
arash
ADI. As I said, it is Alternating Direction Implicit. I do NOT solve the equation as you wrote, you could have seen it in the code I listed there. I solve the equation in two half time steps, n+1/2, and then n+1. At first half time steps, the d2T/dx2 is solved implicitly using TDMA or Thomas algorithm if you are familiar with this, the subroutine for that is listed as well. In first hal time step, it is solved implicitly for x, and a sweep in y-direction is carried out. Then, in the second half time step, between n+1/2 and n+1, d2T/dx2 is assumed known and d2T/dy2 is solved implicitly at time step n+1. For example you can have a look at :
1-CA Fletcher, Computational Techniques for Flud Dynamics, Vol. 1 p. 252
2- TJ Chung, computational fluid dynamics, p. 66
3- JH Ferziger and M Peric, computational methods for fluid dynamics, p. 99
Old   April 6, 2004, 08:07
Default Re: ADI
Sergey Smirnov
I do know what ADI is. If you use it, you don't have a Forward time scheme.
I do not have time to debug your program.
Old   April 6, 2004, 08:31
Default Re: ADI
arash
good for you that you know what is ADI. your mum is proud of you
Old   April 6, 2004, 09:51
Default Re: ADI
ag
Actually the thing that will make it explicit or implicit is what time level the RHS is evaluated at, not the form of the difference used for the time derivative. FTCS is solved in many cases using ADI, when the RHS is evaluated at the n+1 time level. For the original poster, I would suggest doing a time-step study, because ADI is not unconditionally stable. The splitting error grows with the time step you use. Beyond that, what kind of problems are you seeing?
Old   April 6, 2004, 11:10
Default Re: ADI
arash
I found the error, it works now.
Old   April 6, 2004, 23:59
Default ADI stability
pkm
"ADI is not unconditionally stable"
There is a misconception that ADI (in general) is unconditionally stable. Can we have discussion on this.
Old   April 7, 2004, 11:01
Default Re: ADI stability
  #11
ADIar
No ADI is not unconditionally stable, because the RHS is explicitly defined/calculated
Old   April 7, 2004, 13:30
  #12
noName
ADI comes is many flavors, some are unconditionally stable, some are not.
e.g. The 2-step Peaceman Rachford scheme for 2-D parabolic equations is unconditionally stable (for appropriate BCs). But going to 3-D imposes a condition on stability.
A discussion on ADI stability could probably go on forever!
Ref: Chapter 4 of J. W. Thomas, Numerical Partial Differential Equations: Finite Difference Methods, Springer, 1995.
Use SOR or ADI for solving the time dependent reynolds equation Hermano Main CFD Forum 1 July 5, 2010 10:47
ADI implicit doesn't converge George Papadakis Main CFD Forum 2 July 8, 2009 14:27
algo for ADI or fractional step scheme handling crossderivative terms HaKu Main CFD Forum 8 April 4, 2009 03:10
Adi in 2D???sos xiegang Main CFD Forum 0 October 14, 2003 09:04
ADI of N-S equations Zhou Yongcheng Main CFD Forum 5 January 18, 2001 08:58
