problems for the flow over flat wall
Old   March 19, 2010, 05:53
Exclamation problems for the flow over flat wall
L.Y LIN
iilw1314 is on a distinguished road
hi guys ,i need your help for the problems on the flow over flat wall.below is my problem:
it is DNS for the flow over flat wall,the zone is square,1x1 in dimensionless(it can get smaller unit net size by adaptive code),
RE=10000(base on the velocity of the uniform flow of the upper flow domain),Grid is square,the min grid=0.0002,
when x<0.05,i put the uniform flow there.i used the FVM for this problem,
so the process begin.
when i check the result ,i find the velocity outside the bounday layer is larger than the velocity that i set x<0.05,but the velocity in the boundary layer is very good after compared with the value simulated by Blasius,
in one sentence,the velocity out of the layer is larger than the value of the Blasius,it can be 10%larger ,when reach the top of the domain,it still be 5%larger ,
my workmate used the LBM(lattic boltzman method )for the same problem(his RE=50),he have the same problem with me too.
it is strange!
maybe you can help me.thank you ! i am waiting!
iilw1314 is offline   Reply With Quote
flat wall, impressible
tricky flat plate laminar flow sarat FLUENT 4 September 9, 2005 19:35
results for flow past flat plate normal to flow lisa Main CFD Forum 2 August 30, 2005 17:36
The flow from a wall. Wata FLUENT 0 October 19, 2004 08:14
Manipulating flow speed at wall Salman FLUENT 0 April 17, 2003 19:32
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
