particle tracking
Old   March 17, 2010, 18:52
Question particle tracking
banerji
banerji is on a distinguished road
i am simulating a water treatment reactor:it is a simple pipe with with one inlet and one outlet. When I make particle Injection they stop in the middle and I see the report as:
injected:12 escaped:0 incomplete:12
why aren't they coming out and when I checked pathlines they look okay
Please help me if you have an idea
banerji is offline   Reply With Quote
Old   March 19, 2010, 11:32
Wiebe Zoon
wiebe is on a distinguished road
Hi Banerji,
It seems that there is a maximum number of simulation steps for your particle tracking. I don't know what software you use, but there is probably a setting for this somewhere. (Increase it to have more steps.)
Regards,
Wiebe.
wiebe is offline   Reply With Quote
Old   March 19, 2010, 11:44
carmen dain
carmen is on a distinguished road
Hi I’m user of fluent.In my thesis i investigate two phase flow with solid-liquid.We use magnetic force to a field whic magnetic and nonmagnetic particles are suspended in a liquid for separating magneting particles from nonmagnetic particles.can you help me for choosing true model. DPM,mixture,euler which have to be choosen.My solution is dilute
carmen is offline   Reply With Quote
Old   March 19, 2010, 12:21
Wiebe Zoon
Hi Carmen,
For this you probably need to track individual particles, (that means the DPM model) In addition to this, you will need to model the influence of the magnetic field somehow. There is a magnetohydrodynamic module, (search for MHD) but I have no experience using it.
Good luck,
Wiebe.
Old   March 19, 2010, 13:27
carmen dain
thks wiebe but i have a problem for lading particle particle will flow with flow but in dpm it ask me start end stop time what will i do
Old   March 20, 2010, 17:38
banerji
Thank you very much Wiebe, I increased the number of steps and all particles escaped. by the way i am using Fluent.
Old   March 20, 2010, 17:50
banerji
Another small question: does fluent select automatically the appropriate number of particles to inject ? I want to increase the number of particles but i can't find how to do it.
Old   March 24, 2010, 10:48
Wiebe Zoon
The number of particles tracked depends on the type of source. single is just one particle, surface is one particle per cell on the surface, but for example a cone lets you select the number of particles yourself.
Old   March 24, 2010, 10:55
Wiebe Zoon
Hi Carmen,
the start and stop times affect when the particles are released. If for instance your simulation is 100 seconds, but you only want to release a puff of smoke in the first two seconds, set the start time to 0 and the stop time to 2 for the injection. Particles will be tracked the rest of the time, but no new particles will be released.
Wiebe.
Old   March 27, 2010, 15:07
Default gas - particle flow thru CD nozzle
ali
alikami is on a distinguished road
Hi i am simulating flow through a convergent-divergent conical nozzle...
with a laminar only gas solution convergent
with particles also converged but no difference ????
any one can help,,,,
Thanks
Alikami
alikami is offline   Reply With Quote
particle tracking
particle tracking Wenqing Zhang CFX 15 August 3, 2013 07:02
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 13:52
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
restarting lagrange (particle tracking) simulation dbdias CFX 0 September 22, 2007 20:26
Particle Tracking Pravir Kumar Rai FLUENT 0 January 25, 2003 13:13
