April 2, 2004, 11:06 |
how to set the periodic BC in channel?
the channel flow is computed with 3d compressible NS code using MacMarco scheme. in stream wise the periodic bc is used, denoted f_x. in aiaa paper 98-3315, it was -2.*u_taw**2. another paper suggest that it is evaluated using f(d_u/dy). which is better? my code is not valid for this problem now. in initial conditions, all flow parameters is uniform. u=1,v=w=0, density r=1, temperature T=1.(non-dimension) and i add a fluctuate to u within [-0.05,0.05] at inlet boundary in certain time-step. the flow can not develop. i think maybe the initial u is wrong. anyone can send me a velocity profile datas with any Mach number any Renoly number, only compressible. thanks. maybe you would give some advice about it. best regards
Periodic boundary in unsteady flow | ac2011 | FLUENT | 0 | September 26, 2011 07:52 |
How did I set a discharge or depth curve at inflow boundary? (open channel problem) | Andy Chen | FLUENT | 0 | June 29, 2009 11:11 |
Problem installing on 64bit with ver13 | jonititan | OpenFOAM Installation | 5 | May 12, 2006 19:42 |
OpenFOAM installation on SUSE92 problems | derath | OpenFOAM Installation | 1 | April 3, 2006 07:44 |
How to set environment variables | kanishka | OpenFOAM Installation | 1 | September 4, 2005 11:15 |
