how to generate a long annulus then run in FLUENT
Old   March 27, 2004, 19:42
Default how to generate a long annulus then run in FLUENT
zhu chen
Hello, Gurus,
I am a new user of GAMBIT and FLUENT, i am working a small project on annular flow, now i have a problem, i generated a 3D annulus (half part)and meshed, and then run with FLUENT, but sinceit is a 3D problem, I have no idea how to examine the annular velocity distribution, and also, i am not sure of my procedure, and mesh method, is there anyone has an example or tutorial,or existiong one that i can have a look? thank you very much!!
Fluent can't run in parallel when hyper threading turning on. field FLUENT 0 May 5, 2011 08:41
Cannot run fluent 12 kbaker ANSYS Meshing & Geometry 6 February 20, 2011 19:11
Run Fluent in Linux Shamoon Jamshed FLUENT 3 October 26, 2009 12:12
resume and run fluent for another timestep via a c greg FLUENT 2 June 30, 2005 06:01
how to generate an annulus with inner pipe rotate? a person need help Main CFD Forum 0 March 27, 2004 19:46
