March 10, 2010, 02:59 |
mass absorption column
praveen
Rep Power: 17 |
iam simulating the absorption column were i am getting pressures upto 1.23*10^10 pa which is not possible, so wat woulb be the problem.
iam using mass flow rate as inlet boundary condition. presure as atmospheric pressure. and k-epsilon model. and also recovery of species is not showing which i designed for. plz help me out
Praveen Kumar G National Institute of Technology Tirchy |
March 12, 2010, 02:45 |
Rep Power: 16 |
please post more details, i am interested in such case too.
March 15, 2010, 00:36 |
mass transfer column
#3 | |
praveen
Rep Power: 17 |
i want to know which solver solve the mass transfer problems what abt the pressures
March 15, 2010, 03:30 |
Rep Power: 16 |
you should use surface reaction to stimulate mass transfer effect, I think. as to pressure drop, how do you specify the absorption column domain? fluid or porous area.
March 15, 2010, 23:25 |
#5 | |
praveen
Rep Power: 17 |
iam using co2 water absorption. here not only absorpion column with porous zone but also am using parallel plate vertically to distrib the flow for more interaction b/w gas and liquid. so plz if any more information u have r know inform me as soon as possible. and comin to definin the porous zones we will define in gambit and in solver (fluent ) enable porous zones using ergans equation calculate the resistance to to continue
March 21, 2010, 04:11 |
Rep Power: 16 |
so, you mean it will be a mass transfer between liquid and gas. I am sorry I have no idea about it. Maybe, you should apply UDF. If you have any advance, let me know. I am interested in it too. Thank you.
June 6, 2013, 06:44 |
Rep Power: 16 |
Hi
did anyone use in parallel DEFINE_MASS_TRANSFER function? thanks in advance! |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Running dieselFoam error | adorean | OpenFOAM Running, Solving & CFD | 119 | February 1, 2016 15:41 |
gas absorption Column | praveenkumar | FLUENT | 1 | November 23, 2011 01:53 |
Mass flow absorption | Roberto | CFX | 4 | June 27, 2005 12:31 |
