Fluid structure interaction
Like Tree10Likes
Old   November 30, 2012, 18:01
Default contact between solid-fluid
  #21
ben
ben_rg is on a distinguished road
Hi guys
im new here..i have one question.How to create contact part and mesh between solid and fluid in Ansys? Do i have to create separate part between solid and fluid and make it as contact or just combine it as one layer?
my problem is actually simple..i am interested to see pressure or displacement variation after transient impact subjected on the solid surface..let say the air-concrete contact surface.
Currently i am modelling it in ICEM CFD and i am planning to analyse it in FLUENT..anybody has suggestion or idea? Really appreaciate your help.
Thanks in advance
ben_rg is offline   Reply With Quote
Old   December 1, 2012, 05:33
Default RBF Morph
  #22
meb
Marco Evangelos Biancolini
meb is on a distinguished road
The problem could be faced using RBF Morph. We are currently exploring the FSI method using modal approach. It is an effective way to handle it. The limit is the linear hypothesis for the structural part (otherwise modal approach is not applicable). It can be stressed a little bit (i.e. for displacement quite large), however material non linearities and large deformations cannot be covered.
If you need a trial version please contact info@rbf-morph.com.
ben_rg likes this.
meb is offline   Reply With Quote
Old   December 2, 2012, 22:18
Default fluid-solid contact
  #23
ben
Thanks mr. Marco Evangelos Biancolini
Old   August 20, 2013, 10:06
elmer
elmer7 is on a distinguished road
Help, what is the equation of oscillation to simulate the movement of water in a cistern.
thanks in advance.
elmer7 is offline   Reply With Quote
Old   January 14, 2014, 06:36
Andrew Hallow
AndyH is on a distinguished road
Originally Posted by phanh View Post
Hi Marco,
That sounds great! You are right. Using very thin membrane, it is a trick to flag desired mapping surfaces. Could you introduce some reference paper that mentioned this approach?
In NASTRAN, are you using SOL 600? I have seen OpenFSI (by NASTRAN) that is using SOL 600 or 700?
Thank you for your response
Mike
For your information, this group has built a two-way FSI implementation between Matlab and ANSYS Fluent: Fluent-udf.com. Maybe you should contact them?
The example they give is a thin membrane, similar to yours.
AndyH is offline   Reply With Quote
Old   May 21, 2015, 10:16
heavenlysins is on a distinguished road
This youtube link might be helpful for you.
Check it out.
https://www.youtube.com/watch?v=D53vn9GqnoU
heavenlysins is offline   Reply With Quote
Fluid Structure Interaction Apollo Main CFD Forum 5 July 4, 2011 17:15
Fluid Structure Interaction with FreeFem ++ Pierre Main CFD Forum 1 November 21, 2008 00:42
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 04:12
Fluid Structure Interaction Apollo FLUENT 8 July 7, 2004 18:54
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
