Question on the calculation of lift coefficient
Old   February 26, 2010, 05:31
Default Question on the calculation of lift coefficient
mbt
mbt is on a distinguished road
Hi all. The lift coefficient (also drag coefficient) is defined in the form of $C_L=\dfrac{F}{0.5\rho U^2A}$. And my question is in the post-processing step to calculate these coefficients, $A$ should be the sum of the areas of all mesh interfaces related to viscous wall, or it is a pre-defined valued given by the experiments. Many thanks.
mbt is offline   Reply With Quote
Old   February 26, 2010, 12:33
f-w
f-w's Avatar
f-w is on a distinguished road
It's a defined reference area, depends on the experiment, but there are some common ones (like projected wing area). What you described is wetted area, which is also used at times.
f-w is offline   Reply With Quote
Old   February 27, 2010, 08:51
mbt
Many thanks for your reply. I found that in some test cases $A$ is provided as reference value, maybe some type of projected area.
What is the Basic Calculation of Lift Coef In Modelling 2D?? teguhtf FLUENT 0 October 14, 2009 05:52
Lift calculation icem-noob CFX 1 June 23, 2008 07:37
Problem with lift force coefficient summer FLUENT 0 May 7, 2008 11:35
negative lift coefficient? please help! fumie FLUENT 1 October 9, 2007 04:52
drag and lift coefficient Noé Siemens 5 July 13, 2004 11:21
