2d supersonic flow over flat plate
Old   March 10, 2004, 22:47
Default 2d supersonic flow over flat plate
puzzled
Does anybody know the reason why the solution starts to blow up over Ma 9 during iteration ?
I am using time marching Mac Cormack method and changed only free stream velocity as Ma increases.
It was possible to get stable solution by decreasing time step arbitrarily but there existed the limit.
At Ma 25 , the target, the solution blew up however small I set up the time step.
Have a good day, you all.
Old   March 11, 2004, 22:53
Default Re: 2d supersonic flow over flat plate
versi
flow variables jump more as Ma increase. If your numerical scheme rely on numerical viscosity to smooth this jump, it means needing larger viscosity.
Old   March 17, 2004, 19:07
puzzled
Thanks a lot, versi~
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Supersonic flow over flat plate Nikhil Main CFD Forum 6 May 20, 2013 13:48
incompressible, 2-D laminar flow over flat plate... varunjain89 Main CFD Forum 3 March 6, 2012 12:13
Supersonic flow over a flat plate and a blunt body. Maddy FLUENT 0 August 31, 2010 17:35
supersonic flow past flat plate shuo Main CFD Forum 0 July 28, 2007 20:47
