the numerical scheme for LES.
Old   March 8, 2004, 21:29
Default the numerical scheme for LES.
John S
sir
some schemes are used to solve LES equations. such as full-explicit MacMarco scheme, 2-order upwind scheme, high-order upwind scheme, certain centered schemes. which is better for les? upwind scheme is dissipated. can i used 2-order upwind TVD scheme to solve les equations? should anybody tell me some referrence about supersonic circle cylinder. thx
Old   March 11, 2004, 23:23
Default Re: the numerical scheme for LES.
versi
for supersonic flow past cylinder, bow shock will need robust scheme like TVD. But TVD is not good for LES due to its large dissipation and degeneration to 1st order at extrema. I guess your case may be treated fortunately by combination of shock-fitting + higher order finite difference scheme. But for more general cases, ENO, WENO, compact scheme, are more plausible choices, though they produce numerical osciilation at bow shock ,which may affect the flow transition, yet most domain is well resolved..
Old   March 14, 2004, 08:52
Bin Li
I just use second order upwind TVD scheme to compute les equations.should i regard this as MILES?
Numerical viscosity due to the MUSCL and HLL coulpled scheme sonsiest Main CFD Forum 0 May 23, 2011 16:37
How to implement a numerical scheme by using UDF? Furui Xiong FLUENT 0 July 29, 2010 02:30
Numerical scheme in CFX ? sam CFX 1 November 18, 2004 17:25
problem about numerical scheme in LES. libin Main CFD Forum 4 July 1, 2004 05:32
numerical scheme ado Main CFD Forum 3 October 12, 2000 09:20
