static stall
Old   March 7, 2004, 08:28
Default static stall
atrh
hi, i am using fluent 6 to simulate the stall condition. reynold no is 360000. the lift and drag increases as angle of attack increases ( as expected ) but could not perdit stall condition ( decrease in lift and sharp increase in drag ).at 360000 reynold no , the stall should be around 10 to 14 degree . i did try till 22 degree but could simulate stall condition.the y plus is less than 1 at all aoa and aspect ratio is also ok and turbulent to molecular viscosity ratio is about 1.2. i have tried all models but failed to perdit the stall condition.can any one suggest me any thing.
Old   March 9, 2004, 07:07
Default Re: static stall
sylvain
That's the big issue with turbulence models : they can hardly predict stall angle. That's the reason for DES and LES to exist.
Best Regards,
Sylvain
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 05:24
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 17:08
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 01:49
Searchintg Exp. Data of 2D compressible Flow in static stall C-M.Yang Main CFD Forum 1 September 8, 1999 11:47
