Secret Aerodynamics of B2 Stealth
Old   February 6, 2010, 14:46
Administrator
pete's Avatar
Peter Jones
pete will become famous soon enough
The leading edge shape is indeed novel, but not something you would want in an airfoil which must operate well in a range of different incidence angles. The rest of the airfoil is not very novel I think. It is difficult to create an airfoil shape that is novel. Most ideas have been tried.
What cruise Ma number is the airfoil designed for?
Have you done any kind of assesment or simulations involving transition modeling of your airfoil?
pete is offline   Reply With Quote
Old   February 6, 2010, 18:44
bearcat
bearcat is on a distinguished road
Send a message via MSN to bearcat
Originally Posted by dijinj View Post
The lift in airfoil is generated by pressure difference; the lower pressure in upper side of wing is due to higher velocity of air. I am only tryin to make vertical component of velocity zero at trailing edge. the total velocity at upper side is higher in my design too.
1. You don't fully understand the physics. Vertical velocity won't be zero at trailing edge if lift is generated. Consider helicopter's rotor as a wing.
2. Your idea doesn't work. Don't waster time.
bearcat is offline   Reply With Quote
Old   February 6, 2010, 20:29
Diji N J
dijinj is on a distinguished road
Indeed lift is generated but pressure difference is at front end; check pressure contours of cycloid wing. helicopter rotor and propellers are designed in such a way that it pull air downward or back ward respectively. similar to a turbine blade. Here is the data from an inviscid CFD analysis of both cycloid wing and NACA 4412 airfoil
cycloid New improved equal spacing (Angle of Attack 0 degree)
iter continuity x-velocity y-velocity cl cd time/iter
584 1.0582e-06 1.9681e-09 1.4305e-09 3.3978e-01 5.9761e-04 0:02:03 416
585 1.0061e-06 1.9298e-09 1.4192e-09 3.3978e-01 5.9760e-04 0:03:01 415
586 1.0351e-06 1.8866e-09 1.4134e-09 3.3978e-01 5.9760e-04 0:02:25 414
! 587 solution is converged
587 9.9777e-07 1.8463e-09 1.4049e-09 3.3978e-01 5.9759e-04 0:01:55 413
lift to drag ratio = 0.33978 : 0.00059759 = 568.583811
aerofoil (Angle of Attack 0 degree)
! 419 solution is converged
419 9.8097e-07 1.2270e-08 3.7687e-09 6.4636e-01 1.0542e-03 0:02:48 581
lift to drag ratio = 0.64636 :0.0010542 = 613.12843
dijinj is offline   Reply With Quote
Old   February 6, 2010, 20:49
Diji N J
What is your Idea on how lift is generated in airfoils
Old   February 7, 2010, 02:55
Skeptic
Lysistrata is on a distinguished road
If the leading and trailing edges are cusped, it has been done before, e.g.
"A boundary integral equations approach for the study of the subsonic compressible flow past a cusped airfoil", Adrian Carabineanu.
Lysistrata is offline   Reply With Quote
Old   February 7, 2010, 04:36
Diji N J
Actually both Tangents at trailing edge is horizontal but cusp is more general term cycloid is only a member of that group. can you suggest a link of the article "A boundary integral equations approach for the study of the subsonic compressible flow past a cusped airfoil", Adrian Carabineanu. so that I can Cross check whether cycloid is included in article. and especially horizontal velocity vectors are mentioned.
aerodynamics, b2-bomber, stealth
Career in aerodynamics diver79 Main CFD Forum 1 August 21, 2008 17:52
Consultant w/ Expertise in Aerodynamics & CFD Philip Sorensen CFX 4 February 27, 2007 22:12
Consultant w/ Expertise in Aerodynamics & CFD Philip Sorensen Main CFD Forum 7 February 27, 2007 17:54
Consultant w/ Expertise in Aerodynamics & CFD Philip Sorensen FLUENT 0 February 19, 2007 14:45
DOCUMENT EXTERNAL AERODYNAMICS Erdem CFX 0 March 4, 2006 18:48
