Hello, I want to know how I can check the stability of nonlinear system of equation. For example, if I have the following where everything is partial derivative:
du_dt + f(u) du_dx = 0 then, how can I use Neumann stability analysis to analyize a particular discretization of this equation. Any help or references to textbook type information would be most kind. |
Linearity of the equation is a general requirement for the application of the von neumann stability analysis. But in this case your equation is non-linear so , locally linearize the non-linear equation and subsequently apply the von Neumann stability analysis.
I hope this will help. rvndr |
O.k. Thank you for the help. How would you suggest I locally linearise it? Also, how can I show that if the equation is locally lineraised, that it reflects the non-linear version well? In other words, how do I see if linearising it destroys any relation to the orgiinal non linear equation.
when dealing with linear equations you often only need to examine the behaviour of a single component, as all other will behanve similarly.
linearisation of your equation depends on the function of u, i.e. 1D linearlised Burgers equation: du_dt + c du_dx = 0 where c is constant and positive. this is a hyperbolic equation and leads to the CFL condition. if you assume an explicit scheme in your original equation: du_dt + f(u) du_dx = 0 linearisation is trivial, by assuming old values. for an implicit scheme a linearisation method is needed, or alternatively an iteration within a time step can be used. look at the work by beam and warming where it is suggested to expand the flux function using a taylor series. hope this helps |
Any questions about Runge-Kutta methods | Runge_Kutta | Main CFD Forum | 33 | September 9, 2019 16:32 |
nonlinear instability | JackMM | Main CFD Forum | 6 | October 5, 2007 07:20 |
Semi-implicit Runge-Kutta | Bobby | Main CFD Forum | 10 | August 5, 2005 15:43 |
stability criteria | Maciej Matyka | Main CFD Forum | 0 | February 20, 2003 11:41 |
Stability for Nonlinear Numerical Scheme | Guo | Main CFD Forum | 3 | February 12, 2001 12:21 |
