Oscillation (losing stability) ---> unsteady flow?
Old   February 25, 2004, 10:46
Default Oscillation (losing stability) ---> unsteady flow?
HT
In calculaiton using an unsteady approach, do oscillations (odd-even oscillations, look like losing stability) imply that an unsteady flow is going to happen? If yes, how to pull out the correct unsteady solution?
Thanks for your point of view or clues for references.
T
Old   February 25, 2004, 13:29
Default Re: Oscillation (losing stability) ---> unsteady f
ag
Oscillations do not necessarily imply the advent of an unsteady flow. You need to make sure that your loss of "stability" is not a numerical issue. If your algorithm is stable numerically then you can begin to address issues such as numerical damping that can kill a non-steady solution. But if you are picking up odd-even oscillations it sounds to me as if you have a decoupling phenomenon occurring, which is not realistic but a problem with your numerics. Until you fix it you aren't going to be able to get a correct solution.
Airfoil conditions for unsteady flow Dave Main CFD Forum 3 April 24, 2008 18:11
how to predict unsteady flow from case definition? Felix Main CFD Forum 6 August 28, 2007 17:40
Outlet boundary conditions for unsteady flow Bjorn B Main CFD Forum 3 January 11, 2006 06:42
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
Initial Conditions in unsteady turbulent flow Z. Zeng Main CFD Forum 5 April 28, 1999 18:38
