What's the difference in formulation for steady state and time-dependent modeling?
Old   January 22, 2010, 19:49
Default What's the difference in formulation for steady state and time-dependent modeling?
bearcat
bearcat is on a distinguished road
Send a message via MSN to bearcat
Suppose we solve the hyperbolic eq(good for all cases). We have the time term and the computations match in time, explicitly or implicitly. The convergence process will look like a flow field varying in "time" from initial to final steady state. But we don't call it time-dependent or time-accurate modeling. Transient modeling should be something else.
When modeling transient flow on codes like Fluent, one easily notices that the solver performs a few dozen sub-iterations after each time step advancement. But very few CFD books explain how this works, they are all for steady problems.
I know it's a stupid question. But can anyone please explain a little their formulation difference?
Thank you.
bearcat is offline   Reply With Quote
Old   January 23, 2010, 07:32
Farshad
f_panahizadeh is on a distinguished road
Thank you.
please explain your thread more.
f_panahizadeh is offline   Reply With Quote
Old   January 23, 2010, 08:13
Claus Meister
idrama is on a distinguished road
I don't understand you question too, but could your question related to Navier-Stokes-Equation or/and turbulent flow.
Cheers
idrama is offline   Reply With Quote
Old   January 23, 2010, 11:46
Ahmed
Ahmed is on a distinguished road
Thank you.
1- write down the complete NS equations, the classical way
2- move the advection terms to the right hand side
3- Read the equation now
the time rate of change of phi = the total sum of the advection, diffusion and pressure gradients
4- when the left hand side is set equal to zero, then you have reached the steady state solution
In order to reach this numerical zero value, Fluent (or any other programme) discretise the left hand side by , say a first order Runge Kutta technique, and marching in small steps of time reaches the steady state....etc
the rest is explained in most books
good luck
Ahmed is offline   Reply With Quote
Old   January 23, 2010, 13:11
bearcat
Thank you for all your reply. I think I should make the question more clear.
Actually I am talking about the unsteady flow simulation, particularly for incompressible flow. People may use the techniques like "dual-time steps" or "pseudo-time-level" to compute the time-accurate flow field. This is a common topic in CFD applications but very few CFD books talk about it in detail.
Old   January 25, 2010, 20:30
ganesh
ganesh is on a distinguished road
Dear Bearcat,
When you solve the unsteady flow equations, you attempt to update the solution at each time step, from day u^n to u^(n+1). Calculating this solution increment dU itself is a system of equations when considering the more popular and fast implicit schemes. You end up in solving linear systems using iterative solvers (such as Krylov solvers in every Newton iteration or relaxation schemes like SGS after approximating the Jacobian) which are seen as sub iterations at every iteration in physical time. With a suitable accuracy for the time--stepping scheme, this provides for a time-accurate computation, that is of importance for accurate transient simulations.
Hope this helps
Regards,
Ganesh
ganesh is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
time dependent curve faiz rauf FLUENT 0 August 31, 2004 14:02
