Grid size and combustion simulation
Old   February 14, 2004, 04:45
Default Grid size and combustion simulation
versi
In simulating chemcially reacting flow, if I do not want to resolve the chemical time scale, I use implict scheme, selecting the marching time step solely based on CFL number. My Question Is: Is there any restriction on the spatial grid size that is linked with chemical time scale similar to CFL? It seems that the chemical souce terms do not provide any spatial scale.
Old   February 15, 2004, 12:09
Default Re: Grid size and combustion simulation
RMG
Waht kind of wall-treatment/approach are you using?
Old   February 16, 2004, 03:04
versi
My case is inviscid Euler equations. It does not concern with wall law.
Old   February 16, 2004, 05:33
jdc
Hi Versi,
Since chemical reactions occur on a local basic (eg the reaction rate depends only on the local mass fractions), the chemical reaction does not limit your time-step through a "CFL like" relation. However, you should bare in mind the following:
- even using an implicit scheme, your time-step should still be small enough to capture the relevant time-scale of your chemical reaction scheme.
- since the mesh resolution needs to be fine enough to correctly capture the reaction zone, the diffusion limit (called Fourier criteria) may also limit your time-step.
Have fun. Julien
Old   February 16, 2004, 07:42
Salvador
Everything depends on what are you studying. In combustion processes usually a lof of species and reactions are involved. Some of the reactions are very fast others are very slow, all this makes the treatment of the chemical source terms very stiff, which means that your time step is reduced ENOURMOUSLY. Usually an implicit scheme is performed for the chemical source terms to alleviate these symptoms. Again, everyhtnig depends, if you are using some equilibrium assumptions or infinitely fast chemistry, this restriction changes. In non-premixed combustion you can used pre-computed flamelets, for example. Usually, in RANS, hundreds of chemical iterations are needed for just one flow field step. Again, if you want to solve everyhting (DNS),usually chemical time scales are shorter than Kolmogorov (turbulent) scales, the reaction zone is thinner. Check you Damokhler and Reynolds numbers
Guides for calculation of mesh size for combustion Luk CFX 4 March 17, 2008 03:34
vortex breakdown daniel Main CFD Forum 13 February 19, 2004 11:25
Help, gas combustion, grid quality, convergence boji CFX 1 September 16, 2002 09:46
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Combustion Flow Simulation in the Incinerator Jin Wook LEE Main CFD Forum 5 July 26, 1999 21:07
