I cannot solve Pro. 6.5 in the Book by Patankar,
Old   February 11, 2004, 13:41
Default I cannot solve Pro. 6.5 in the Book by Patankar,
KE
I am sorry to bother you all. Now I am reading the book " Numerical heat transfer and fluid flow" by Pro.Patankar, and sovle the problems following chapters. But it's difficulat to discretize it properly, onec I discretize it, it seems there is not enough boundary conditions to complete the " Simple" procedure. your help and advice will be appreciated.
Regards
Ke
Old   February 12, 2004, 11:59
Default Re: I cannot solve Pro. 6.5 in the Book by Patanka
centaur_ks
problem is stated well but it has a twist though. i have solved it earlier. here is a suggation. USE UPWIND SCHEME TO DISCRITIZE CONVECTIVE TERM AT POINT A. This will eliminate your point 1 for which you dont have the data.
Old   February 12, 2004, 21:43
Ke
Thanks for your advice, I will try it.
Good weekend.
Old   February 13, 2004, 11:16
Default Problem 6.5 solved, thanks again
Ke
I sovled the problem 6.5 yesterday, using upwind method to avoid bothering the point beyond point 3. And I also lineaized the (uA)u term before the iterations were put into practice.
Thanks
Good Day.
Spectral Methods in Fluid Dynamics Martin Bailon Main CFD Forum 3 January 31, 2011 14:39
Linearized NS euqations: how to solve them?(problem with Matrix operations..) matteoL OpenFOAM Running, Solving & CFD 0 November 18, 2009 07:58
free on line compressible flow book genick bar-meir Main CFD Forum 4 December 5, 2005 01:25
free on line compressible flow book genick bar-meir Main CFD Forum 0 November 9, 2005 21:56
How to solve another continuum and momentum eqn? west_wing FLUENT 0 August 25, 2003 11:00
