February 7, 2004, 08:38 |
hyperbolic equations
Hi friends
For One-Demensional wave equation (which is hyperbolic) and for One-Dimensional Inviscid Burger's eqn.(which is also hyperbolic eqn) Explicit schemes give good result or explicit schemes are the best bet. Then can we make the statement like this " For hyperbolic eqn's explicit schemes are the best bet ?".If not the case in which cases they are ? Thanks in advance. regards rvndr |
February 7, 2004, 13:03 |
Re: hyperbolic equations
Implicit and explicit schemes refer to time discretization. Explicit schemes are restricted by the well-known CFL condition which puts an upper limit on the allowable time step dt. This means that you will have to perform more time steps to reach the desired solution. Explicit schemes have a more relaxed CFL condition which allows you to take larger time steps dt.
February 9, 2004, 09:19 |
You could say: when the CFL condition is physically appropriate, explicit schemes are the best choice. However, for example for Euler equations, the shocks travel usually at the speed of the fluid, not at the speed of sound. In that case, the CFL condition is far too restrictive and implicit schemes are much better than explicit ones.
February 9, 2004, 19:28 |
as i know the the CFL condition is taken at maximum wave speed u+c
Guide: Writing Equations in LaTeX on the CFD Online Forums | pete | Site Help, Feedback & Discussions | 27 | May 19, 2022 04:19 |
Type of PDE: Hyperbolic or Parabolic or Elliptic? | Guo | Main CFD Forum | 8 | August 17, 2018 10:34 |
CFD governing equations | m.gos | Main CFD Forum | 0 | April 30, 2011 15:21 |
Fifth order anti diffusive scheme for 1D hyperbolic heat transfer | areffallah | Main CFD Forum | 0 | November 3, 2010 05:48 |
Lax-Wendroff solve hyperbolic equations | zyf | Main CFD Forum | 0 | July 14, 2003 05:53 |
