mesh requirement for LES
Old   February 5, 2004, 23:30
Default mesh requirement for LES
Jason
LES generally require finer mesh compared to RANS models,if this understanding is correct, what is the acceptable mesh size in the near wall region when I am using LES for engineering problems? thanks.
Old   February 10, 2004, 17:48
Default Re: mesh requirement for LES
frederic Felteb
Hi there,
Usually you would want to use a mesh where y+=1 for the first point in the off-wall direction. Then depending on the type of flow, the requirement for the streamwise and spanwise directions can be more relaxed. For example, in a typical LES turbulent channel flow, you would use x+=50, z+=25 and y+=1
I hope this helps,
Sincerely,
Frederic Felten.
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 09:07
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
