December 11, 2009, 05:50 |
Help on SIMPLE algorithm!!
Thiyagarajan dhayalan
Rep Power: 17 |
Hi all,
i have written a code for SIMPLE algorithm in a pipe flow in a 2d domain.at the inlet i specify u velocity and at outlet iam specifying outflow i.e gradient velocity is zero(du/dx=0).I didn't specify any presssure boundary condition.Upon solving iam getting uniform u velocity and zero pressure value everywhere.Any suggestions.thanks for ur time reg Thiyaga. |
December 31, 2009, 04:15 |
SIMPLE problem
Prakash Ayappan
Rep Power: 17 |
I am also facing the same problem, I am anlaysis for 2D arbitary duct.
Can any one help... |
February 23, 2010, 02:16 |
#3 | |
prashant kadam
Rep Power: 16 |
February 23, 2010, 06:06 |
Rep Power: 17 |
I don't think SIMPLE is enough for internal / duct flow. Global mass flow may not be conserved even if cell wise the flow is divergence free. I think this is the same reason why one can't exactly get an agreement with the analytical Blasius profile and the profile obtained with SIMPLE like algorithms. Internal flow / or stream wise dominant flow should be modeled as Parabolic PDE, if you are interested in getting the fully developed laminar profiles. I read in Patankar book, in one of the last three chapters, that SIMPLER should be used instead for one direction dominant flow. Further, if you are efficient in writing codes you may include a secant procedure to preserve global mass conservation. read for instance this paper. www.asu.edu/courses/che331/cfd_code.pdf the paper is written for education journal but follow the refernces to further see the issues I raised. By the way if what I said is wrong, someone explain it to me and I would retract what I wrote above. Cheers TAW |
simple |
SIMPLE algorithm in 3D cylindrical coordinates | zouchu | Main CFD Forum | 1 | January 20, 2014 18:02 |
SIMPLE algorithm for collocated storage | alex | Main CFD Forum | 4 | April 9, 2008 00:48 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | Main CFD Forum | 0 | April 18, 2007 04:48 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | FLUENT | 0 | April 14, 2007 00:17 |
SIMPLE algorithm | Jonathan Castro | Main CFD Forum | 3 | December 10, 1999 05:59 |
