Problems in mesh motion solutor in parallel 4 interDyMFoam.
Old   November 21, 2009, 17:17
Exclamation Problems in mesh motion solutor in parallel 4 interDyMFoam.
DLC
Davide Lupo Conti
DLC is on a distinguished road
I'm using OpenFOAM 1.5-dev. I'm using the interDyMFoam solutor to run a free surface flow test case (a cube floating in water). I've modified a bit the floatingBody classes, but nothing of major importance.
I don't have problems in running the simulation in serial (one processor), but when I try to run the same case in parallel (on four processors) the simulation gets stuck though I think I've done all things correctly, using decomposePar.
I've done a bit of debugging and found out that the coode gets stuck on the solutor of the laplacian for the mesh motion in sixDofMotion.C,
more precisely in fvMesh::movePoints(motionPtr_->newPoints()).
the problem seems to be in newPoints().
In the end I found out that the problem seems to be in laplaceTetDecompositionMotionSolver.C in the line solverPerf_ = motionEqn.solve(). Unfortunately I couldn't get any 'deeper' than that in the code.
Does anybody have an idea why the simulation runs in serial and not in parallel? I mean, isn't pretty wierd that running in parallel gives problems in the solutor for the mesh motion? Any idea can be very useful!
thanks to all
Davide
DLC is offline   Reply With Quote
interdymfoam, parallel
Problems in mesh motion solutor in parallel 4 interDyMFoam. DLC OpenFOAM 0 November 21, 2009 09:54
unusual mesh motion...............help me out samad87 FLUENT 1 August 10, 2009 02:02
Mesh motion Hex cells vs tets kev4573 OpenFOAM Running, Solving & CFD 6 December 13, 2007 15:37
mesh motion emma chen FLUENT 0 September 26, 2003 10:14
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
