wall surface temperature
Old   November 20, 2009, 22:45
Default wall surface temperature
jinhuic86 is on a distinguished road
I specify an internal heat generation for a solid block surrounded by the air domain, the surface temperature of that block is calculated based on free convection between the block and its surrounding air. the problem is the surface temperature is way too high. is it due to the mesh? Thanks.
jinhuic86 is offline   Reply With Quote
Old   November 22, 2009, 00:27
Ahmed
Ahmed is on a distinguished road
I do not think the mesh has got to do with the surface temperature in a natural convection problem, it depends, in your case, to how much is the amount of heat generation and the surface area (try to touch a 100W light bulb few minutes after you turn it on).
Good luck
Ahmed is offline   Reply With Quote
Old   November 22, 2009, 23:54
I am just concerned that the boundary layer may not be modeled properly with the mesh near the surface. Do you think those commercial codes might have issue on this? Thanks.
Old   November 23, 2009, 01:25
Ahmed
if you are worried about the quality of your mesh, you can either
repeat your analysis with a denser mesh, or attach a picture of your mesh and details about your analysis so the readers of this forum can give their advice.
Good Luck
Old   November 24, 2009, 08:32
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
Dear friends:
I think the problem is the wrong heat source value in the block region.
recheck it.
ztdep is offline   Reply With Quote
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
Non-conformal grid interfaces: wall temperature Evandro FLUENT 0 April 4, 2008 00:43
How to input the wall temperature b.c.? Jimmy Siemens 9 March 14, 2008 10:31
How to input the wall temperature b.c.? Jimmy Siemens 16 March 7, 2008 15:11
heat transfer with constant wall temperature Marco FLUENT 0 December 8, 2005 08:16
