November 8, 2009, 19:19 |
blasius flow simulation using SIMPLE method
Kamyar
Rep Power: 17 |
I developed a code using SIMPLE method in order to simulate incompressible flow over a flat plate ( Blasius flow ). The code diverges when I increase Reynolds number more than 1000. I already use constant pressure at inlet and outlet and also zero pressure gradients at top and bottom boundaries
I want to know what are the best pressure boundary conditions for this problem? The grid is uniform and staggerd thank you |
December 18, 2011, 11:49 |
Rep Power: 15 |
hw did you handled d fictitious boundaries,I mean d one's for u- & v- velocities. wl u be kind enough to mail me ur code? my email id is soumyabrata111@gmail.com
calculate volume flow from a 2D simulation | SimonH. | OpenFOAM | 0 | October 27, 2009 05:39 |
Simple method for fluid flow in 3D | abdou | Main CFD Forum | 9 | November 9, 2004 06:53 |
tidal flow simulation using finite volume method | Jason Qiu | Main CFD Forum | 0 | October 20, 2002 03:34 |
SIMPLE method for compressible flow in pipe | Reza | Main CFD Forum | 0 | August 27, 2002 23:43 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
