how to deal with the surface roughness?
Old   January 4, 2004, 10:41
Default how to deal with the surface roughness?
maximus
I have to consider the roughness effect on heat transfer in the flow near the rough wall.and I find the traditional method is to use the boundary layer integration which can include the roughess effect by using the roughness Renolds number.Another method is to modify the log-law of velocity near the wall.here my question is if there is a turbulence model or a wall funtion which can include the roughness effect. thanks.
Old   January 5, 2004, 06:31
Default Re: how to deal with the surface roughness?
Nicola
K-omega model by Wilcox provides a simple method to include roughness effect by prescribing a Dirichlet-type boundary condition at wall for omega. For the details, see the Chima's report at www.grc.nasa.gov/WWW/5810/webpage/docs/kw6.pdf. You can also refer to the paper of Wilcox himself: Reassessment of the scale determining equation for advanced turbulence models, AIAA Journal, 26, 1299-1310. Best regards,
Nicola
Old   January 5, 2004, 07:57
maximus
hi,Nicola,I am very appreciate for your advice.I've got the first paper you told me,but Can you tell me the exact year of the second paper in AIAA Journal(AIAA Journal, 26, 1299-1310,????).And i wonder if it is diffcult to include the roughness effect in k-e model.Because I use the k-e model in my codes,I am trying to find a method to include the roughness effect in k-e model. thanks. maximus.
Old   January 7, 2004, 05:35
Nicola
Maximus, I'm sorry for the late answer. The exact reference is Vol. 26 No. 11 November 1988. As far as the k-e model is concerned, I can only tell you that in the case of the Star-CD code, roughness effects are taken into account by wall functions, but I don't know if there is some other method. I suggest you a careful search using google. Best regards,
Nicola
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 08:13
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Surface roughness alefem FLOW-3D 6 June 3, 2010 13:49
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
