About compressible flow at low mach
Old   October 26, 2009, 09:31
Red face About compressible flow at low mach
hit
WANG
hit is on a distinguished road
Dear CFD friends,
now,I have a question about calculation of compressible flow at low mach,But I can not get a good result.I can not find reasons. Calculation condition as follows:
[1]stream flow Mach number M=0.01
[2]Rey=6e4
[3]space: MUSCL method
Roe average method
[4]time: LUSGS method
[5]Laminar flow method(Compressible flow Code is used)
By these conditions,for example,If Roe-average method is used at very low Mach number(Mach number M=0.01) by Compressible flow Code,Can I get good result?
Thanks
hit is offline   Reply With Quote
Old   October 26, 2009, 11:19
Praveen. C
praveen is on a distinguished road
You will get very bad results at such low mach numbers with a compressible code. You need to use some preconditioner. A easy preconditioner for roe scheme can be found in
Herve and Viozat
http://citeseerx.ist.psu.edu/viewdoc...10.1.1.35.2610
praveen is offline   Reply With Quote
Old   October 26, 2009, 22:21
Rudhi Kurniawan
Kurniawan is on a distinguished road
Hi, im mechanical engineering student and i make an unsteady compressible navier-stokes simulation at low speed, using C++, mccormack scheme.
when i place an obstacle, i got good result, with 1500 iteration i can see that the flow is convergence and it has vortex flow on it. Beautiful ...
The problem is interaction between fluid flow and boundary is very weak, what should i do to fix it??? It is channel flow with u = 3 m/s, channel length 10 cm, height 10 cm.
can somebody help me???
Kurniawan is offline   Reply With Quote
urgent help needed with 2d compressible flow James FLUENT 2 June 20, 2007 05:22
low speed compressible two phase flow?? cat CFX 0 November 15, 2005 08:59
Compressible code at low Mach numbers Peter Main CFD Forum 7 May 15, 2003 08:12
Low Reynolds, compressible flow andre burdet Main CFD Forum 0 February 21, 2001 12:13
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 18:23
