questions about adaptation
Old   April 6, 1999, 02:52
Default questions about adaptation
Lebeau alexandre
What is exactly Y+? How do you choose(calculate) the size of the first cell? thanks for your help Al.
Old   April 6, 1999, 06:25
Default Re: questions about adaptation
andy
y+ is a non dimensional distance from a wall.
You choose the the size of the first cell to adequately resolve the flow and/or satisfy the requirements of the near wall treatment. This is principally a function of the turbulence model, the near wall treatment and the state of the flow adjacent to the wall. The requirments for an LES prediction are very different to that for a RANS k-e prediction. The requirements for a thin boundary layer can be significantly different to that for a thick boundary layer.
I would recommend reading something about near wall turbulence before tackling the CFD. A good introduction is contained in:
P. Bradshaw, "An introduction to turbulence and its measurement", Pergamon Press, 1971.
It is fairly widely held in libraries.
Old   April 6, 1999, 11:26
David Creech
y+, the nondimensional distance from the wall, is defined as
y+=DeltaY*[(density^2 * Cmu^(1/2) * K)^(1/2)]/mu
for K-e turbulence models. DeltaY is the actual distance from the wall.
For the standard K-e model, y+ for the first cell should be 100 < y+ < 300. For the Low K-e model, y+ should be less than 1. Note that all of this depends on the code and model that you are using, it is just a general guideline.
David Creech
The CFX Subroutine Archive
Axisymmetric 2D mesh adaptation - ERROR Pepe CFX 3 May 30, 2011 09:28
Regarding the adaptation of scalarTransport Foam as well as general openFOAM logic. HFonten1 OpenFOAM 0 August 10, 2010 14:05
NACA0012 Validation Case Questions ozzythewise Main CFD Forum 3 August 3, 2010 15:39
mesh adaptation for hexa mesh Pete CFX 4 April 6, 2005 19:43
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 14:47
