question about les filter?
Old   December 16, 2003, 21:52
Default question about les filter?
Bin Li
dear all
The filter is used in LES with FDM, and the filter width is 2 delta_x(supposed 1D). Question is that if the bigger width is used, the results of the fluid field are more accuracy? it is that, how the filter width affect on the results of LES?
best regards.
Old   December 18, 2003, 11:31
Default Re: question about les filter?
frederic Felten
Hi there,
Take a look at the following paper: ``On the use of discrete filters for large eddy simulation'',T. S. Lund, CTR Annual Research Briefs, Stanford, 1997.
Available online at: http://ctr-sgi1.stanford.edu/CTR/ResBriefs97/lund.ps.gz
Sincerely,
Frederic Felten.
Old   January 21, 2004, 13:04
Anup
A smaller filter width implies that you are resolving more of the turbulent scales and modeling fewer small scales.
Explicit filtering in LES TJ Main CFD Forum 85 November 30, 2016 06:22
LES supersonic flow ziooscuro OpenFOAM Running, Solving & CFD 1 March 5, 2011 01:56
Basic LES question toyCFD Main CFD Forum 3 August 23, 2006 16:09
Naive question about turbulence and LES Renato Main CFD Forum 1 October 5, 2005 00:01
A Question on the Dynamic procedure in LES dragon Main CFD Forum 1 April 28, 2005 16:11
