pulsating flow
Old   December 4, 2003, 06:05
Default pulsating flow
Pete
Consider a straight pipe (1.6mm bore, 80mm long) which is filled with Helium (300psi) and the flow is pulsating (+/-50psi). It pulsates at approximately 80Hz. Does anyone know of any CFD that has been performed on similar situations.
Old   December 4, 2003, 16:32
Default Re: pulsating flow
CFDRookie
The basic text Ch. 10.5.4 on CFD by Versteeg & Malalasekera gives a basic non-dimensional overview for a circular pipe at low and high frequencies along with math references to the overall flow behaviour and applied studies. Boundary Layer Theory (1979) by Schlichting gives the analytical solution fitting the bore-pipe length ratios of your problem.
Old   December 9, 2003, 12:39
Pete
cheers I'll have a look
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 23:08
average volume flow rate carno FLUENT 0 April 12, 2007 07:37
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
Plug Flow Franck Main CFD Forum 3 September 4, 2003 06:57
