2d nozzle simulation, need help
Old   September 26, 2009, 02:49
Default 2d nozzle simulation, need help
Swee5420
swee5420 is on a distinguished road
I am currently conducting a project of simulating supersonic flow in a nozzle in 2d.
My problem is how to define the area of the inlet and outlet of the nozzle, since the reporting surface area is incorrect.
For example, the inlet has a diameter of 21mm, hence the actual area should be A=D^2 x pi /4 = 3.46E-4. But the reporting surface area is 21mm^2, which leads to an incorrect reporting mass flowrate too.
How do i change the surface area so that the reporting area, mass flowrate will be correct?
Thanks in advance
swee5420 is offline   Reply With Quote
Old   September 30, 2009, 02:41
Default supersonic flow analysis of 2D Nozzle
sharanappa
sharan is on a distinguished road
Send a message via Yahoo to sharan
Are you using any software for the simulation ? if yes which software are you using. In software you need not calculate any areas. I have done a similar project using Fluent on a C-D nozzle considering the upper half since is axi-symmetric. In such case area should be equal to radius(r)*depth(d) and since the depth is unity so area is equal to r m^2.
If you can tell me about the type of nozzle you have chosen and other details I can help you further.
sharan is offline   Reply With Quote
Old   September 30, 2009, 06:32
Rami Ben-Zvi
Rami is on a distinguished road
Seems like your software is unaware of your geometry being axisymmetric, and treats it as planar of unit thickness.
Rami is offline   Reply With Quote
Old   May 24, 2012, 01:33
Arif
upal_arif is on a distinguished road
Looking for qualified freelancer to simulate supersonic flow through C-D nozzle using fluent 6.2.16
please contact upal_arif@yahoo.com
upal_arif is offline   Reply With Quote
2d nozzle, surface area
convergent_divergent nozzle simulation in CFX-11 sivarama1 CFX 22 February 18, 2013 17:23
Boundary condition for supesonic nozzle simulation Abhinav Choudhari FLUENT 6 September 26, 2009 05:31
Nozzle Flow Simulation Winnie CFX 0 August 24, 2007 11:10
Nozzle flow simulation in inviscid and viscous Cath FLUENT 0 January 28, 2007 03:16
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
