analysis of naca2412 airfoil
Old   September 25, 2009, 19:32
Default analysis of naca2412 airfoil
gaurav
gaurav is on a distinguished road
I am trying to analyse a 2-d model of a naca2412 Airfoil (cord length 1 meter) at an angle of attack of 16 degrees to calculate the coefficient of lift using "WIND-US" . But my solution never seems to converge. I have run about a 1,20,000 iterations yet it keeps oscillating consistently between 0.7 and 2.2. It keeps generating the same pattern.
I have the following conditions
pressure: 15.4 psi
temperature: 540 R
velocity: 0.2 Mach
angle of attack: 16 degrees
Laminar flow.
I am using the roe scheme 3 order . Kindly suggest .
Thanks.
gaurav is offline   Reply With Quote
Old   September 26, 2009, 22:33
Default naca2412 16 degrees
Dr Peter Murdoch
meon is on a distinguished road
Sounds like its stalling. 16 degrees is close to the stall angle.
Check the pressure plot on the upper surface at the chord positions 0.2 0.4 0.6 0.8.
If you really need to get this to solve try running it as a transient, start at 10 degree aoa and then slowly increase it.
That should do the trick.
meon is offline   Reply With Quote
Old   September 26, 2009, 23:54
gaurav
Thanks a lot for your advice I shall definitely try it and get back to you.
Multi-element airfoil analysis CFD Rookie Main CFD Forum 12 November 17, 2016 07:07
airfoil analysis Hammam CFX 10 June 22, 2007 14:18
Airfoil Mesh for DES Analysis - y+ Value asd Main CFD Forum 1 May 3, 2007 11:13
y+ for Airfoil Analysis asd Main CFD Forum 3 April 18, 2007 11:54
quasi steady analysis of 2d airfoil (pitching) Alex FLUENT 1 February 10, 2006 03:54
