implementing continuity equation at walls
Old   November 24, 2003, 14:24
Default implementing continuity equation at walls
Subhra Datta
wall tangential velocity components will have zero gradients (and zero value) along wall due to no slip and this from differential form of continuity equation (consider 2-D for simplicity)implies wall normal component will have zero gradient on wall (in addition to being zero for non-porous boundaries)...
how is this implemented in a cfd code..I read somewhere that while discretizing in Control Volume formulation the first derivative of the normal velocity on faces aligned with walls should be made zero...
I have faced some problems when I implemented this (which I will mention in a new thread)...anyone who have success doing this or something similar/more/more appropriate on this line...
Old   November 25, 2003, 01:24
Default Re: implementing continuity equation at walls
versi
in Control Volume formulation the first derivative of the normal velocity on faces aligned with walls should be made zero: --> where do you use this derived condition, in normal shear stress, or in pressure Poisson eq.? usually, noslip condition is enough.
Old   November 25, 2003, 02:58
Subhra Datta
in normal stress..
Old   November 27, 2003, 00:57
Sun
I agree with versi, no-slip condition is sufficient. Why not leave the gradient of tangential velocity as it is (probably not zero) in the normal stress. It seems to me no need to force it to be zero at all.
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Continuity equation not satisfied in cavitating gearpump klunker FLUENT 0 March 9, 2010 11:46
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
how to adjust continuity equation in vof??? Asghari FLUENT 0 October 11, 2006 05:43
