Wall temperature define in fluent
Old   September 22, 2009, 12:53
Default Wall temperature define in fluent
Dezhi Zheng
zdz198728 is on a distinguished road
Hi, guys:
If I put adiabatic wall temperature boundary condition, combustion happened around the wall. Should the wall temperature equal to fluid temperature when the case reach to steady state? From my case , the answer is no. So Could anyone help me to explain this?thanks
zdz198728 is offline   Reply With Quote
Old   September 23, 2009, 00:58
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
radiation?
ztdep is offline   Reply With Quote
Old   September 23, 2009, 11:14
Dezhi Zheng
I keep radiation on, however, the emissivy I set is zero.
Old   November 19, 2009, 01:37
Charles Rundle
Charles Rundle is on a distinguished road
If I may ask, is there any reason that you set the wall's emissivity to zero? I am assuming that the radiation model was left on to account for radiation given off by the combustion and the medium is treated as participating.
I would expect that the default radiation settings would probably use the emissivity for the absorptivity as well. Which means that your walls are being treated a perfect reflector. Any radiation generated will be reflected back thought the fluid until the fluid absorbs it all again. This may be exactly what you are looking for in which case ignore this part. As I mentioned before combustion is not my area of expertise.
Also how uniform is your fluid temperature? The net radiation flux is zero; to be adiabatic the wall only has to be the same temperature as the fluid adjacent to the wall. There may be a very sharp gradient in temperature near the wall which allows for a substantial difference between bulk fluid temperature and wall temperature despite being adiabatic.
I hope this is helpful and I haven't covered material you already know. Have a good day.
CAR
Charles Rundle is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
[blockMesh] StitchMesh on two patches anita OpenFOAM Meshing & Mesh Conversion 31 April 4, 2013 12:51
udf variable for wall temperature Kiran FLUENT 0 July 31, 2008 09:31
how to get the change of temperature of a wall shoeb Siemens 2 November 30, 2004 14:44
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
