September 18, 2009, 11:26 |
Small Y+
Shannon Galway
Rep Power: 17 |
Is there a disadvantage to a small Y+? I know for shear stress transport models I am looking for a Y+ less than approximately 2. Is there a disadvantage/error to having this number much smaller than that (like 0.2 for example)?
September 25, 2009, 10:08 |
federico
Rep Power: 17 |
Are you simulating a wall-bounded turbulent flow? if you use DNS or LES your first computational node off the wall must be at y1+ = 1 or even y1+=0.5, but this mean a very large ammount of nodes. With wall function (this means that you are not making DNS anymore) you can put your first node in the log zone, so y1+ > 30, and you can save the number of computational nodes.
September 25, 2009, 14:43 |
kumar
Rep Power: 17 |
Hi For wall integration grids we need to have y plus around 0.2 to 1. where as with the low y plus values you will see some convergence issues. With the low y plus values there is possibility to predict wrong gradients. That will screw up your complete solution.
September 25, 2009, 23:23 |
#4 | ||
Shannon Galway
Rep Power: 17 |
Thanks for all the help. I really appreciate it. |
why did Time step is too small in stiffbs? | satum | FLUENT | 1 | December 10, 2012 10:15 |
Do small boats slow big boats? | Richard Scott | Main CFD Forum | 13 | August 3, 2004 04:51 |
SGS small scales == fluctuant scales ?? | Bin Li | Main CFD Forum | 6 | February 26, 2004 13:35 |
what happens if y+ is too large or too small | Bo Jensen | Siemens | 12 | February 20, 2003 00:31 |
small size holes simulation | brian ko | Phoenics | 5 | October 22, 2001 13:53 |
