Slot jet in crossflow
Old   September 15, 2009, 04:58
Default Slot jet in crossflow
Rungroj W.
Sammy is on a distinguished road
I'm studying in slot jet in crossflow which can be simulated in 2D and I simulate with k-epsilon turbulence model. Crossflow is 3 cm/s and uniform velocity profile. Jet velocity is 30 cm/s. Slot jet width is 0.5 cm. I apply wall function for bottom boundary and normal gradient at outlet boundary. At top boundary is symmetry. I have problem with upstream distrance (before jet exit). This parameter has an effect to my result when I compare with experiment data. Anybody have experience about this problem. Thank you in advance
Sammy is offline   Reply With Quote
Old   September 15, 2009, 10:30
Continuum
Continuum is on a distinguished road
I would be interested in making a simulation comparison. Can you post your geometry and current results?
Continuum is offline   Reply With Quote
Old   September 16, 2009, 01:55
Rungroj W.
My geometry, upstream is in range 10-100D
downstream is 400D
crossflow channel height 240D
I compare my result by plotting jet trajectory at velocity ratio (jet/crossflow) 10. I have read many papers. Almost use upstream is not over than 12D but my result is near the experiment data at 100D.
Give me your e-mail so I will send a plot of experiment data.
How to craete a cylinder with slot jet. Hamdy Phoenics 3 December 14, 2007 16:41
Slot jet impinging on cylinder Diz CFX 0 September 24, 2007 22:34
Slot jet in cross flow. Hamdy FLUENT 0 March 5, 2006 05:04
Slot jet in cross flow. Hamdy Phoenics 0 March 5, 2006 05:01
sonic Jet in crossflow (slot injection), cfl no amol palekar Main CFD Forum 1 November 14, 2004 21:46
