need to run in batch
Old   September 14, 2009, 15:18
Default need to run in batch
al mazdeh
amazdeh is on a distinguished road
the following line od code will use the initial steady state run as an initial values for my transient run-I need to run the job in batch mode-
system "cfx5solve -def PLATEJET_500.def -ini PLATEJET_ke_001.res";
the mesh in def file and res file is different-
CFX by default always ignore the mesh in def file-
I can change that manually if I don't use batch mode-
but in batch I do not know how to force CFX to apply interpolatation method to use the mesh in def file
thanks for your help
amazdeh is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Error within a batch run Jia Li CFX 7 July 29, 2010 19:54
batch run N.R. CFX 1 June 17, 2007 23:44
data output from batch fluent run Wang FLUENT 4 March 11, 2005 12:01
run f;uent job in batch mode? jx FLUENT 5 July 2, 2003 12:29
