Help required in plot3d format
Old   September 11, 2009, 10:48
Default Help required in plot3d format
Kishore Kumar C
Kishore is on a distinguished road
I am to post process output generated in plot3d format produced by a opensource solver called ISAAC( integrated solution algorithm for arbitrary cases). I have two ascii formatted files
1. '*.g.fmt' ---> called grid file
2. '*.q.fmt' ---> called solution file
I tried using a free to use postprocessor called MayaVi. It asks for xyz file and q file. I have 'q' file whereas I suspected the xyz file would be the grid file. I tried giving the 'g.fmt' file in place of xyz file. It doesnt open. I googled for xyz file format and couldnt get it.
1. If any one can help me in telling the format of xyz file format, it would be of
great help.
2. Is grid file and xyz file one and the same?
3. Anyone here have experience using ISAAC?
Please reply
Kishore is offline   Reply With Quote
Old   September 11, 2009, 12:21
Praveen. C
praveen is on a distinguished road
Hi
I have used ISAAC. Mayavi support for plot3d is rather basic. You can try cgx from Calculix
http://www.calculix.de/
which can read these plot3d files. Or you can convert them to some other format. I have written a program to convert to vtk format, see
http://svn.berlios.de/viewcvs/nuwtun/trunk/src-utl/
There is one program to convert 2d files and one for 3d files. They work only for single block plot3d files. But you can easily modify them for multiblock.
VTK files can be seen using the free and excellent software paraview http://www.paraview.org
praveen is offline   Reply With Quote
Old   September 12, 2009, 08:35
Kishore Kumar C
Hi Praveen,
Thank you so much for your reply. I am really happy to know there is someone who uses ISAAC.Will try your suggestions and let you know.
Old   September 15, 2009, 02:51
Kishore Kumar C
Dear Praveen,
I tried running plot2vtk_2d.f in Microsoft visual fortran in a 32 bit XP platform,
It says the 'Specify one argument' and then exits. It doesn't ask for any file name or anything.Kindly tell me how to go about this?
Regards,
Kishore
Old   September 15, 2009, 05:21
Praveen. C
ISAAC gives you output files like
naca.g.fmt
naca.q.fmt
etc.
You run
plot2vtk_2d naca
to create vtk file naca.vtk which can be viewed in paraview or visit.
Old   September 15, 2009, 08:06
Kishore Kumar C
Thank you so much Mr.Praveen. Your suggestion works!.
Thanks once again
isaac, plot3d
Help! Extract statistics from DNS (plot3d format) sarah_ron Main CFD Forum 0 March 13, 2007 00:53
How to export plot3d format from icem/cfd Harry Main CFD Forum 2 November 24, 2006 18:00
Format for importing Plot3d files into Star-CCM+ Meredith Siemens 1 October 12, 2005 13:28
plot3d file format joew Main CFD Forum 1 April 27, 2002 00:05
Grid Generator for Plot3d format Jens Bennetsen Main CFD Forum 0 September 12, 2000 06:00
