Drag on non-infinite cylinder between parallel walls
Old   September 10, 2009, 14:01
Default Drag on non-infinite cylinder between parallel walls
deltaquattro is on a distinguished road
I'm looking for correlations which give the drag coefficient on a circular cylinder of diameter D and length L, confined between parallel walls: the incoming flow is in the x direction, the axis of the cylinder is along the y direction, the two walls are respectively at y=0 and y=L, and the flow is unbounded in the z direction. Obviously in the limit D/L -> +infinity, this reduces to the classical flow around a 2D (or infinite) circular cylinder.
I wasn't able to find any correlations for the case in which D/L is finite and small (between 0.5 and 4, let's say). I only found something when the axis of the cylinder is along x, e.g a cylinder "suspended" between the walls, with the flow impacting on one of its bases.
I'm sure this is a problem which has been already treated a billion of times, so there must be some data. Can you point me to some references? Thank you,
Best Regards
Sergio Rossi
ps I'm even more interested in the case when you have an infinite array of cylinders in the z direction, separated by a distance H...
deltaquattro is offline   Reply With Quote
drag coefficient of cylinder Avijit FLUENT 12 April 23, 2017 04:26
Drag Coefficient Verification around Cylinder MFerris CFX 44 May 11, 2015 19:27
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 11:50
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
drag calulation over a square cylinder sex00 Main CFD Forum 4 February 2, 2001 08:16
