LES filter
Old   November 13, 2003, 23:27
Default LES filter
xing zhang
I have a question about LES.Is the 'filter' only used for theoritical analysis or it has to be implemented in the code? Nuemrical method such as FVM is a 'implicit filter', isn't it? So if the grid is fine enough, and sub-grid turbulence model is used, then it is LES, no explicit filter is needed, is that true?
Old   November 14, 2003, 08:13
Default Re: LES filter
Lionel Larcheveque
Almost all LES are carried out without an explicit filtering of the N-S equations because the mesh and the numerical method act as implicit filters. However, some LES purists recommend to use an explicit filtering in order to reduce error in subgrid modeling.
Moreover, filters are required for some subgrid models, such as dynamic Smagorinsky : they're used to obtain a test field with higher cutoff length to take advantage of Germano's identity.
Hope this helps
Best regards.
Old   November 14, 2003, 15:27
Dean
If you explicitly compute the Leonard terms, you need to specify a filter.
Old   November 15, 2003, 14:50
senthil
Unless otherwise one uses dynamic family of models people donot use explicit filters. ALthough some use.
filter width in LES Kai Main CFD Forum 7 February 17, 2019 22:03
Bugs in LES filter codes yekaniyasari OpenFOAM Bugs 4 February 19, 2018 07:51
calculation of test filter quantites for desired parameters(equations) in les mrn FLUENT 0 July 15, 2010 06:04
LES with different filter Rick Main CFD Forum 1 August 22, 2008 19:10
question about les filter? Bin Li Main CFD Forum 2 January 21, 2004 13:04
