Boundary layer strategy for port flow case?
Old   September 3, 2009, 23:09
Default Boundary layer strategy for port flow case?
Digital_Junkie
MaxCFM is on a distinguished road
I need some advice on setting up boundary layers for an automotive port flow case. The case I'm working on now is an intake port. The inlet/outlet pressure differential is 6975 Pa. I'm using a realizable k-epsilon model and the case has about 3 million cells. Minimum cell size in the valve clearance area is .25 mm. Valve lift (2 valves) is 14 mm. Can someone please provide some guidance on how many prism layers to use and how to size them? Thank you for your time.
MaxCFM is offline   Reply With Quote
Old   September 9, 2009, 07:09
Digital_Junkie
Can anyone please give me some guidance?
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 08:20
boundary layer thickness for pipe flow ranjith CFX 4 September 13, 2015 23:29
Is boundary layer "a must" in turbulence flow? Pingaroo FLUENT 3 May 25, 2009 12:09
2D Boundary Layer Development in CFX11 Chris Basciano CFX 1 August 28, 2008 17:15
Boundary layer flow goes the wrong way andimb OpenFOAM Running, Solving & CFD 2 March 20, 2006 09:51
