CFD versus Wind Tunnel Test
Old   November 11, 2003, 04:45
Default CFD versus Wind Tunnel Test
wuttichai
1.I would like to know how I can use CFD without using wind tunnel test. 2.How can I find out drag force acting on car body in CFD for Drag Coefficient. 3.I would like to know papers or literatures about using CFD instead of experiment (Wind Tunnel Test) in aspect of procedure, method and analysis. Please recieve my thank in advance for your assistances.
Old   November 11, 2003, 05:25
Default Re: CFD versus Wind Tunnel Test
K.M. BAZEETH AHAMED
There are some softwares in which u can simulate the windtunnel conditions for example mach n0. temperatuure etc. execution of the program will give the lift drag etc., you can find this in a on-line java applet program in the website of NASA.
Old   November 11, 2003, 06:11
wuttichai
Thank you very much for our comments. However, if I would like to use other general purposed CFD commercial code such as ANSYS, Fluent etc., Can you recommend how?
Old   November 12, 2003, 01:07
Des Aubery
Sawasdee krap Khun Wuttichai,
What is the exact nature of your project?
A car in the wind-tunnel - there are a number of CFD software packages available... The accuracy of your answers is what is ultimately important - IMHO this will depend more on your modelling technique, than the software itself...
Regards,
Des Aubery... (adTherm Technology - www.adtherm.com - des@adtherm.com)
Mesh inverse volume - wind tunnel roald CFX 1 January 11, 2011 17:45
defining velocity profile in a wind tunnel model Erdem FLUENT 0 June 20, 2006 14:00
Virtual Wind Tunnel in FLUENT ND FLUENT 0 April 7, 2006 08:43
Comparing wind tunnel tests costs with CFD Freeman Main CFD Forum 9 January 30, 2006 09:02
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
