information required
Old   July 24, 1998, 18:11
Default information required
wiqi
I want to know the method to calculate pressure,lift & drag coeficients if pressure distributions & velocity distributions on airfoil are found by FLUENT CODE.
Thanks.
Old   July 24, 1998, 21:52
Default Re: information required
John C. Chien
I thought FLUENT Company should have already taken care of this basic question. The only reason why you are computing flow over an airfoil is to get the lift and the drag coefficients. Unfortunately, this seemingly simple question is going to be very difficult to answer. The lift and the drag coefficients are the global quantities, which can only be obtained accurately when the 1) wall pressure distribution on the surface of the airfoil and 2) skin friction distribution on the surface of the airfoil are both exact solutions. This should be a simple task of surface integration. The skin friction is related to the turbulence modeling in general and the mesh and the numerical schemes. In the case of an airfoil flow and a positive angle of attack, the lower surface flow is accerlating, and is easier to model. The upper rear surface flow is decelerating, the current turbulence models still have difficulties in handling this region correctly. ( as I always say, the commercial code is a black box, the best place to get an answer is the support engineer of the developer company.)
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
[OpenFOAM] Problem with paraFoam on a linux-64 bit bunni ParaView 4 April 14, 2010 21:55
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
information required on k-e model Tejus Gautham Kumar Phoenics 2 March 10, 2005 22:07
