Blending funtction F1 for SST turbublence model |
September 1, 2009, 13:35 |
Rep Power: 17 |
I am confused about the blending function for SST model:
in Menter's paper, he said, F1 switch to one inside of boundary layer? But in my case i found in the free surface, I got F1=one also. Is that ok? or something wrong? Thanks in advance! |
September 2, 2009, 05:48 |
Rep Power: 17 |
F1 is formulated so that it is 1 in boundary layer and in regions of adverse pressure gradient. This switches the k-w part of the model in these situations. In the freestream it should be one. Check your formulation and the variables of F1. I would suggest have a look at the value of vorticity in the problematic area to see if it is behaving the way it should.
September 2, 2009, 13:50 |
Rep Power: 17 |
Thanks for your reply!
I checked the formula, it was right and also the wall distance calculated rightly. For my cases I got a good convergence with regular k-w, but if i use sst k-w it did not convergence very well and F1 is one in some other region besides boundary layer. Last day i tired to set F1=one and F2=zero everywhere and switch the SST boundary to K-w boundary conditions, It was supposed to get the same results as regular k-omega, but I did not. And I found somethings confused at wall boundary for omega equation: 1, for regular K-w, w=7.2*Nu/Y**2 at y=y1 2, for SST, w=10*6*Nu/beta_1/Y**2=800*Nu/Y**2 at y=0 (beta_1=0.075) My question are: 1, what does y=y1 and y=0 mean? what i understand is: y=y1 mean we specify this value to the first cell above the wall boundary, and y=0 mean we need to specify this value at wall face. Is that right? 2, cause w in SST model is 1/0.09 times w in the regular K-w model, so those two values are not identical.If they are same, the SST model w should equal to 6*Nu/beta_1/Y**2. SO why they are different? Any suggestions will be appreciated Thanks! |
September 4, 2009, 05:06 |
Rep Power: 17 |
I don't remember much detail about the Wilcox model, but according to the paper by Menter http://ntrs.nasa.gov/archive/nasa/ca...1993013620.pdf , in Wilcox's model, y is the distance from cell to the wall. It is the same in SST model, but in SST at the near wall cell, the value for Wilcox's w is multiplied by 10 as it gives much more accurate value for w. In general, because w is used to dampen the turbulence near wall, w values are expected to work better when they are high. Menter modified the w values to increase accuracy and to make it easier to implement in traditional CFD environment.
model | han | Main CFD Forum | 0 | September 27, 2005 09:35 |
references about the fan/radiator model | Mihai ARGHIR | Main CFD Forum | 1 | January 8, 2001 16:49 |
references about the fan/radiator model | Mihai ARGHIR | Main CFD Forum | 0 | December 21, 2000 04:06 |
references about the fan/radiator model | Mihai ARGHIR | Main CFD Forum | 1 | December 17, 2000 08:01 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 05:34 |
