August 27, 2009, 08:04 |
Mesh Independence - Valid Strategy?
Rep Power: 17 |
Dear All,
I'm running a mesh independance study - solve same problem on coarse, medium & fine meshes & examining solution from each, in the hope my parameter (head loss) converges towards the analytical solution as the mesh is refined & gives an indication of the mesh size necessary for acceptably small error. I have a convoluted passage which is my geometry of interest, to which I've added artificial inlet and outlet extensions. At the end of these I apply boundary conditions. My question is with an eye on maintaining manageable mesh sizes - am I correct in thinking I can leave areas of the mesh which aren't of interest (extended inlet and outlets) unrefined, and only refine the areas I am studying? Is this still a valid mesh dependance study? Thanks! Ianto. |
August 27, 2009, 08:17 |
Rep Power: 17 |
In any kind of meshing, it is necessarry to have smooth transition between mesh sizes. So, if you are refining your mesh in the region of importance, you would have to refine your mesh in the extruded regions (especially near the interface of your interior to boundary region) aswell so the gradients etc are calculated properly and so their effect on the interior mesh. The mesh in outlet region will perhaps have more effect in the solution than that at the inlet owing to the effect of boundary values on the calculation of the interior cells.
August 31, 2009, 04:36 |
Shyam
Rep Power: 17 |
If I am right, what you intended to do is local refinement. It could give you a (grid) converged solution. But, what you are trying to do is to remove the errors only in that region. You still need to be sure that the errors generated in the rest of the region is smaller than the region of interest (which you refined). To check it, you can probably do two grid refinements (coarse to medium) with first one refined locally, and second one refined globally.
[Other] vtk mesh or Abaqus mesh to OpenFOAM | bigphil | OpenFOAM Meshing & Mesh Conversion | 27 | November 23, 2015 17:31 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
unstructured mesh grid independence for Fluent | Shane Schouten | FLUENT | 0 | October 11, 2006 16:50 |
Mesh Independence and Y + | sam | FLUENT | 1 | September 13, 2006 05:50 |
