August 22, 2009, 20:16 |
CFD ACE,need help
Bazz
Hi all,
I am doing a part time research degree and working on the study of a multiphase flow (coal particles/air) through a pipeline using CFD ACE. Could i get some help with the following questions please? 1.What format have the files (pipe drawings) need to be before they can be loaded onto CFD ACE? 2.How do i convert 2d pipe drawings from autocad to the required format onto CFD ACE in 3D format? 3.Because i do a part time research, have no previous experience and work from home, i have found it difficult to get help on using the CFD ACE software? Are there books available that take you through the steps of using CFD ACE? Thanks in advance, Bazz. |
January 17, 2012, 05:23 |
Majid S.
Rep Power: 14 |
hello,
are you still using ACE+ for your research ?? |
January 18, 2012, 13:47 |
Rahul
Rep Power: 14 |
hi
1)ACE+ allow to import .DTF , nastan, patran,IGES,STL format file files. 2) you can import your geometry in IGES format or you can export your CAD file to GEOM or ICEM-CFD then extrude tour 2d into 3d and then export into DTF. this DTF you can use in ACE+ simulation. |
January 26, 2012, 05:08 |
bp
hi Majid,
Yes, I am still using CFD ace. Have you used CFD ace? Bp |
January 26, 2012, 05:09 |
bp
Hi rahul,
have you used CFD Ace? Bazza |
cfd ace, new user |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 20, 2015 00:40 |
STAR-Works : Mainstream CAD with CFD | CD adapco Group Marketing | Siemens | 0 | February 13, 2002 13:23 |
ASME CFD Symposium - Call for Papers | Chris Kleijn | Main CFD Forum | 0 | September 25, 2001 11:17 |
ASME CFD Symposium | Chris Kleijn | Main CFD Forum | 0 | August 22, 2001 07:41 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
