August 20, 2009, 12:36 |
Pressure coefficient in SIMPLE Algorithm
hi everybody
I have a question about calculating pressure-correction Eq's coefficients. I don't know how could I determine that, should I determine them after correcting u* and use new u* for calculating aI,J or by using guessed velocity field? thank you. |
August 21, 2009, 01:55 |
hey
zobekenobe
Rep Power: 17 |
i use the colocated grid along with momentum interpolation ....so in that case when i am writing the cell face velocities ...they are the obtained by the linear interpolation of the cell centred velocities (the ones that were alredy predicted)...and hence in the pressure correction equations you have these cell face velocities that come into play.
August 22, 2009, 02:36 |
Mohammad Reza Hadian
Rep Power: 17 |
i use collocated grid and the calculation is :
1-solving u and v momentum and calculating u* and v* 2- calculating cell face velocities by momentum interpolation using calculated cell center u*, v* and cell face velocities of last iteration and time step. 3-solving pressure correction eq. (the cell face velocities calculated in step 2) 4- correcting cell center and cell face velocities |
pressure coefficient, simple |
How to give pressure boundary condition in SIMPLER algorithm | shyamprasad | Main CFD Forum | 0 | March 17, 2009 00:40 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 12:26 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Problem in Result of the pressure coefficient | Ken Choi | Main CFD Forum | 2 | March 15, 1999 05:15 |
