Can vorticity or pressure coefficient plots be used to explain the thrust and lift?
Old   August 18, 2009, 21:05
Default Can vorticity or pressure coefficient plots be used to explain the thrust and lift?
TWB
quarkz is on a distinguished road
I have simulated moving airfoils and computed the thrust and lift.
How can I use the vorticity or pressure coefficient plots obtained to explain the reason for the high or low thrust and lift of the airfoil?
Is there any useful references?
Thanks!
quarkz is offline   Reply With Quote
Old   August 19, 2009, 00:55
Dominic Chandar
dominic is on a distinguished road
Send a message via Skype™ to dominic
From the pressure distribution, it is rather hard to determine how thrust is produced from an oscillating airfoil ( I assume oscillating since you mention thrust generation). I have used the vorticity moment equations to explain why thrust is generated from plunge/pitch etc. If you want, send me ur email, I can send you the paper..
Dominic
dominic is offline   Reply With Quote
Old   March 8, 2016, 16:03
Default Please Help
Pradip
pradip.c1000 is on a distinguished road
Hi quarkz,
I have same problem as you how did you calculate the Thrust and efficiency for propulsive? Thanks in advance. My email id is pradip.c1000@gmail.com
pradip.c1000 is offline   Reply With Quote
