Confused
Old   October 23, 2003, 08:14
Default Confused
littlelz
Hi, dear all:
I met a very strange problem today. I was really confused. Please help me!
I am going to define a size distribution function based on maximum entropy formalism model. So, I defined the function's name is Maximum_Entropy. However, you know, it doesn't work right. I check every thing (actually the procedure is very simple), and finally found everything is all right, but the function's name. If I change it, I mean to use any other name except the first letter 'm'(for example, add a letter 'a' in front of the present name), then everything is OK!
Don't you think it's very funny and incredible? But i want to tell you it's really happened! So, who can tell me why?
Many thanks!
Old   October 23, 2003, 09:12
Default Re: Confused
cfd dude
Just a guess:
In Fortran, unless you explicitly declare otherwise, it's implied that all variables that start with the letters I-N are integers. All variables starting with letters A-H and O-Z are reals.
Therefore as you originally had it, you were trying to return a real value to an integer variable.
Yes?
Old   October 23, 2003, 10:23
Bart Prast
ALWAYS use "implicit none" I would say.
Old   October 23, 2003, 10:59
Default Still Confused
littlelz
Hi, Above all:
Thanks a lot for your help!
Hust as you said, the procedure is regarding the function's name as a integal variable. However, after I use "implicit none', the procedure ask me to define its type. When you reference a defined function in your main program, do you need to re-define the type of the functions' name. My answer is 'No'. The defined function just as the system function, such as 'COS', 'SIN' etc. I was confused again!
Old   October 23, 2003, 11:45
Default Re: Still Confused
cfd dude
When you use implicit none, you must declare every single variable you use! This is by far the safest programming practice.
Declare your function as:
real function max_entropy(args)
... function coding ...
max_entropy = (some result)
return
end function
Then in your main code:
result = max_entropy(args)
With this, the function is declared to return a real variable. You can declare functions to return integers, logicals, etc. in the same manner.
I think if you don't explicitly declare the function it will return whatever the name corresponds to (A-H,O-Z returns real, I-N returns integer).
Old   October 23, 2003, 12:31
littlelz
Hi, thanks a lot! Unfortunately, as I try it as you said, I was still confused!
I declare my function as:
real max_entropy
return
end function
Then in my main code:
result = max_entropy(args), no any other type definition. Then, the debug told me the function name has no type definition. But in fact, I have define it in the function procedure. I also tried your definition method. The debug still say there is no type definition. It means that I have to define its type explicitly in the main code. Is it 'fair'?
Old   October 23, 2003, 12:38
cfd dude
You must declare in your main code:
real max_entropy
to tell the compiler what type of variable the function returns. Every function that returns a value must be declared in the main routine.
You should also declare the function as:
with the "real" definition included, to be explicitly clear.
Old   October 23, 2003, 13:31
Default Thank you very much
littlelz
Old   October 23, 2003, 13:43
Default Re: Thank you very much
cfd dude
CFD - Continuous Fortran Debugging!
Confused with solvers / Radiaton model mixanologos OpenFOAM Running, Solving & CFD 3 October 25, 2011 07:58
Confused about how these variables are used gchnhn Main CFD Forum 0 October 3, 2011 04:44
Questions about tutorial from User Guide :confused: inginer OpenFOAM 4 May 25, 2010 16:10
confused on messages after solver has terminated mactech001 CFX 1 April 21, 2010 17:58
Confused F Main CFD Forum 6 August 9, 2004 06:32
