Open boundary condition for 1d euler equation?
Old   July 28, 2009, 18:19
Default Open boundary condition for 1d euler equation?
Ashley is on a distinguished road
What is the open outflow nonreflecting boundary condition for 1d Euler equations?
thank you
Ashley is offline   Reply With Quote
Old   July 29, 2009, 06:18
Vinayender
vinayender is on a distinguished road
Sloving a local Reiman problem, or solving the Reiman Invarients along the there waves u,u+a and u-a at the eixt would work as a non reflective boundary condition.
Thanks ,
Vinayender
vinayender is offline   Reply With Quote
Old   July 31, 2009, 13:34
Thank you very much.I have calculated the exact solution using method of characteristics.Did you mean that I can put those values as the outflow BC?
thanks alot
Old   August 3, 2009, 05:05
Vinayender
Yes right but, dont calculate them manually and give as the BC,,,
because you have the flow properties variying across the exit of the domain. That is
on left side state of the normal outward vector on the outlet will be varying and your right side state would be fixed by free stream conditions, so let your code calculate the exact fluxs on all the faces on the outlet bc in every iteration.
And rember this method would be good enough only if there is no wake passing through outlet. (As method of charatraristics is appicable only for isentropic flows). So incase you fell that some wake is moving out of the oulet then make your outlet bc very far such that by the time this wake reaches the outlet it would have smeared out removing all the graidients.
Thanks ,
Vinayender
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
open channel boundary condition hamed_roozegar FLUENT 0 May 27, 2009 02:17
Rotating interpolated boundary condition hani OpenFOAM Running, Solving & CFD 0 July 4, 2006 08:09
